Page 1 of 12 1234511 ... LastLast
Results 1 to 20 of 239
Thread: done dug a hole i think
    Jun 2013
    207
    alright I got customers 2007 tbss 6.0 previously tuned by someone else , added a magnasen supercharger running bout 8 to 10 pounds of boost he says 42lb injectors he says , so I bought the tuning school new edition guide and seemed to do ok till I got to the wot part, and I ant real sure where to go now, It stumbles and boggs and seems farther away than when I started, any help would be preciated ill try to load a file an scan
    Tuning Addict
    6,873
    It's stumbling and bogging because it's lean....... Unless you have a boost reference regulator, 42lb injectors will never be big enough for that much airflow on that displacement - just one of the reasons why the MAF is all screwed up... Another observation just looking at the log - why does your map max at 103kpa while looking at your MAF hz, your obviously running at least up into the 180's kpa range - Is the right map in this thing - never mind looked at the tune - obviously correct map was never installed? You also need to log more after fixing the current problems...
    Just some quick observations.
    ~Greg Huggins~
    Feb 2006
    South Carolina
    1,525
    It's stumbling and bogging because it's lean....... Unless you have a boost reference regulator, 42lb injectors will never be big enough for that much airflow on that displacement... Another observation just looking at the log - why does your map max at 103kpa while looking at your MAF hz, your obviously running at least up into the 180's kpa range - Is the right map in this thing - never mind looked at the tune - obviously correct map was never installed? You also need to log more...
    Magnassun kits, out of the box, use the stock MAP.
    Jaime
    Jun 2013
    207
    I don't think it was part of a kit , I think he grabbed somethin from here and there , I swear it was like trying to unbake a cake
    Tuning Addict
    6,873
    Quote Originally Posted by ElecTech View Post
    I know - I hate that... We sell them
    ~Greg Huggins~
    Jun 2013
    207
    how do i fix your quick observations, i called myself following the guide but not sure what i started with, and i don't know enough yet to change things without knowing what it does
    Tuning Addict
    6,873
    Quote Originally Posted by jessiewalls View Post
    Ohhhh, so it's one of "THOSE" kits That explains the injectors.... Hope everything was installed correctly since it appears the owner did the install himself - seems like that has bit me more times than anything
    ~Greg Huggins~
    Jun 2013
    207
    injector suggestions? he seems willing to buy whatever is needed,i just don't know what he needs yet
    Jun 2013
    207
    I'm confident i got all his install errors fixed, and it was a lot butnow I'm down to the tuning and such as
    Tuning Addict
    6,873
    You can go as big as ID1000's as long as you use the double stoic half flow rate trick - this will be the best route without having to full scale the tune... It looks like you have a mechanical fuel pressure regulator via the tune - if you do - you can figure out how to possibly plumb in a boost reference regulator - this would allow you to run smaller injectors, but still wouldn't go much smaller than ID850's...
    Guess the better questions are - Do you have a mechanical regulator? Which magnuson blower setup do you have - heartbeat?
    You'll also want to see if you can't install a 3 bar map - may require different pigtail connector - both decently priced though GM dealer...
    ~Greg Huggins~
    Jun 2013
    207
    stock fuel system for 2007 tbss, the supercharger is like the ones that came on the ss chevy trucks with a smaller pulley I might be able to find the size wanna say 144but wouldnot bet my check on it,
    I did see the map and that's what confused me
    Tuning Addict
    6,873
    This one? It should have come with injectors.... And if memory serves you either have a regulator built into the filter or it's fixed fuel pressure via built into the sender in the tank...
    http://www.magnusonproducts.com/p-83...ercharger.aspx
    ~Greg Huggins~
    Jun 2013
    207
    thV5J6FKAM.jpg looks like this one with different injectors
    Tuning Addict
    6,873
    So it's got a different TB and everything then? AND he installed the factory SS injectors into it - I assume he purchased it used and is making it work then... OK at least we've got more info now
    ~Greg Huggins~
    Jun 2013
    207
    its definetly gumbo , the tuning school tuned the same vehicle 2 years ago before the supercharger,
    he bought the injectors from duetchewerks ran great still not sure why he messed with it
    Jun 2013
    207
    no clue what the tb came off of
    or maf or map
    Jun 2013
    207
    if I know what to get I think can figure it out but I need a solid starting point cause I aint sure where to start
    Jun 2013
    207
    is there anywhere to get someone to remote tune/help fer this stuff?
    Tuning Addict
    6,873
    Still a little confused with the blower - the one pictured looks like the old cable style TB - possibly 3 bolt setup? Can't see the pic that great... Has the TB been changed to a different size?
    SO, I guess the best question is what all has been done exactly? Sorry to come off like an ass here or any previously Just trying to get some info for everyone...
    ~Greg Huggins~
    Jun 2013
    207
    oh don't worry , u tryin to help me I'm gonna yessir and nosir hat in hand , cause u don't have to help
