Differences view appears to be working now
You report 'em, we fix 'em!
We got this guy Not Sure, ...
I'll try to break some more stuff then
I'm pretty sure you can open 2.24 .hst(histogram files) with 3.0/3.2 so I don't believe you'll need to rebuild them more than you will just drag them over.
That's a function of the user interface. Not all vehicles support populating that function.
It's there for every vehicle you connect to.
On the HPT lock question.
Are we no longer able to lock tunes at all?
We had 0 issues with this in 3.0 for the dodges we tune.
It's an important feature for us.
Ron
Yeah, I read that.
Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
06 Cobalt SS bought new
Awesome! I have a 2016 F-150 5.0 and will be putting on 35" tires. Is this version able to adjust for tire and gear changes?
In trying to figure out which throttle position I need to log to get it to read over 88% I stumbled upon this.
These are the three throttle position parameters that are available to me and they all are reporting different things. Also the chart is all saw toothed, but I think I remember that being caused for someone else by logging more than one of the same parameter.
Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
Support sent me this in response to the TPS charting looking like that, and they are correct, the issue corrected when i followed their instructions. "With the generic parameter it is trying to pull the data from the multiple channels. If you go into charts layout and pick a specific parameter then only that one specific parameter will be displayed. "
Stupid question, but how does one pick a specific parameter? I thought that was what we were all ready doing when we picked a said parameter...
~Greg Huggins~
since 2.x a long, long time ago the charts default to using "sensors" for common values like Vehicle Speed, Engine Speed, MAP, ECT etc. so that it was easier to use the same charts across multiple vehicles that might use different actual PIDs to log them (as mentioned you can choose a specific parameter if you edit the chart properties). The sawtooth is caused by the new 3.x scanner plotting engine that doesn't average multiple PIDs for the same sensor, every datapacket received is timestamped and displayed individually.
I count sheep in hex...
I had seen many people reported this issue with the release of 3.1 beta. so i was under the assumption the bug was probably overly reported.
to all you guys busting ass for us needy tuner folk. Yall have a development rate thats far surpassed the competitions! Which i feel is under appreciated to say the least.
