Page 12 of 30 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 585
Thread: AEM 30-0300 Wideband with direct CAN integration W/ VCMScanner. Need beta testers.
  1. #221
    Tuner iced98lx's Avatar
    Jul 2008
    Sioux Falls, SD
    58
    I don't know if I'd pull from the ODB2 port. I would suggest a switch letting you warm the car (and thus the o2 sensor) up prior to turning it on since I'm sure most of the pull is during heating the sensor but I think I read somewhere that is a big no no and will destroy the sensor.
    Seems the C5's and C6's have a separate fuse for the 12v in the dash and the 12v in the center console, so could be easy to rob the power from one or the other (whichever you don't use to charge your phone):
    http://www.thevettebarn.com/forums/c...inop-fuse.html
    That's likely the route I'll go...
    (Sorry that got Corvette specific)
  2. #222
    Jul 2008
    Sioux Falls, SD
    58
    Just got mine, I like that everything but the power connection is pre-wired/terminated in plugs. Screw the sensor in, plug everything in with 12v power and off you go. Still need to find a spot for the gauge.
  3. #223
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Remember if it's a pre-CAN vehicle you have to add resistors to CAN wires
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  4. #224
    Sep 2002
    Chicago, IL
    6,412
    We've received a few support tickets from VPW customers.
    I don't believe the AEM WB CAN OBD device is working on VPW vehicles currently, even with the resistor. It's a unique scenario as having two OBD supported busses is in violation, so we haven't spent a lot of time making that work yet.
    We got this guy Not Sure, ...
  5. #225
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Well, that officially sucks if it won't work on a 2005 corvette. I don't know what VPW is but I'm assuming it's some sort of obd protocol?
  6. #226
    Jul 2008
    Sioux Falls, SD
    58
    mine is an 08 so it should be good to go as I understand it...
  7. #227
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Yeah I think you're fine. I on the other hand, not so much
  8. #228
    Jul 2008
    Sioux Falls, SD
    58
    No doubt, that's super annoying. Best explanation I found: http://www.obdtester.com/obd2_protocols
  9. #229
    Feb 2006
    South Carolina
    1,525
    Pretty sure the E40 (2005 Vette) is a CAN ECU. An Info Log will tell for sure.
    Jaime
  10. #230
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    I think you're right... heres what it said
    Hardware: 0121
    Firmware: 0120
    PartNumber: 0000006220
    BuildDate: 7/9/2008 12:00:00 AM
    InterfaceOnTime: 10.05:07:29.4550000
    ROM: 00 3F 00 82 00 01 00 FC FF
    Config: CC 88 00 00 00 C0
    System Info: F7 00 00 00
    Comm Errors: 40 00 00 00 00
    SPI Info: 20 15 A5 5A 4E 41 00 00
    VehicleConnectedTime: 10.05:07:29.4550000
    DetectedProtocols: VPW, CAN
    SAE J1979 Info: CAN, 500 kb/s, Standard 11 bit, 500 kb/s, ECM: 7E8
    ECM: 7E8, CAN - E40, GM Gen4 V8
    VIN: 1G1YY24U855104906 - 2005 Chevrolet Corvette, 6.0 L, 8 Cyl
    Serial: 86YKWAM0426607P2
    OS: 1250161
    Calibration IDs: 12613186, 12599005, 12605744, 12595751, 12618497, 12597183, 12596661, 12595737
    Calibration VNs: 00009189, 00005E67, 00005AB2, 000037E9, 00004AE3, 0000E30F, 0000367D, 00005E7A
    Basic PIDs: 43
    Trouble Codes:
    P0102 - Mass or Volume Air Flow A Circuit Low (Pending, Current)
    P0443 - Evaporative Emission System Purge Control Valve Circuit (Pending, Current)
    Controller Type ID By OS: 5020
    Diagnostic Requirements: None
    Scanning Methods: ISO 15031-5 Mode 0x01 Functional, ISO 15031-5 Mode 0x01 Physical, SAE J2190 Mode 0x22, HPT Mode
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  11. #231
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Quote Originally Posted by jcmg8 View Post
    According to the specifications the 30-0300 draws peak 3amps
    Connected it to a power supply earlier. During normal operation it pulls about 0.8 amps. During warm up it's about double that. So the 3 amps number was probably a little higher than it'll ever actually use.. but figured I'd post my findings.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  12. #232
    May 2016
    41
    Quote Originally Posted by Keith@HPTuners View Post
    I would be one of those customers. It will not work on my 00 TA. With the resistor, the AEM WB is all the scanner sees. All the pids from the pcm are grayed out. I guess I will have to use the analog signals. I hope they are able to get this working.
  13. #233
    May 2016
    41
    Has this ever worked on non canbus vehicles, because I thought they had it working at one time? I tried an older version of 3.0 last night, still didn't work.
  14. #234
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    I thought it was working on older vehicles too, at least at one point.
  15. #235
    Jul 2008
    Sioux Falls, SD
    58
    Nice I think that provides ample (pun intended) options for power connection withing tracing a dedicated line back to the battery.
  16. #236
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Yeah, I think I'm going to connect mine to a 12V cigarette adapter plug at first and see how that does. Will make it super easy to install for tuning other peoples cars. Just install O2 sensor, plug into OBD, plug into 12V lighter and you're good to go
  17. #237
    Tuner Stuffs's Avatar
    Dec 2013
    Denver
    111
    ... anytime is a 2008+ non vpw protocol car?
  18. #238
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Not sure what you're asking
  19. #239
    Dec 2008
    on the Dyno
    1,825
    My customer is using it on a '12 CTS-V and anytime he starts the scanner the WB Channel disappears from the list and doesn't populate data. Sort of in a bind because he's using the standard cable with no way to log WB data in other than this CAN system. So we are basically stuck until this is figured out. He is using 3.0.128 since it still has the channel available to even add to the channel list. 3.2.11 doesn't even have the channel listed to add to the channel list.
    Located in Central Kentucky
    ShorTuning
  20. #240
    Jul 2008
    Sioux Falls, SD
    58
    Quote Originally Posted by Stuffs View Post
    I assume he's pointing out that you're "good to go" as long as the car is CAN BUS compatible and not VPW, which is true, yes.
