Page 12 of 23 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 459
Thread: VCM Suite 3.2 is here!
  1. #221
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    To clarify - the min/max override feature was intended only for overriding HPT-set limits in cases where the ECM actually supports higher values.
    So if the ECM software was only meant to work with a value of 1.0, even though the data structure may support a value of 2, the ECM may ignore anything above 2.
    In other words, I would not adjust the values unless you're absolutely certain that the software supports these (higher or lower) values.
  2. #222
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by Engineer@HPT View Post
    I am not seeing any adverse effects with it at 1.9, I may change it back to 1.0 though....
    In either case, could there be some other table that might be missing or undecoded (I don't know much about that part of this) causing this issue? I wish I could help more with that.
  3. #223
    Jan 2012
    Cessnock NSW
    73
    In my 2.24 for e38 under speedi there use to be tyre and gear calculator which auto adjusted the shift speeds if you changed tyre size or diff ratio, ive downloaded 3.2 and this feature appears to have been removed? Or has it been put some where else?
    Its a handy tool to have
  4. #224
    28,319
    Quote Originally Posted by redmonaro View Post
    http://www.hptuners.com/forum/showth...753#post414753
  5. #225
    Tuning Addict
    6,903
    Under Edit Now...
    ~Greg Huggins~
  6. #226
    Jan 2012
    Cessnock NSW
    73
    Its not in this location for my 2009 G8
  7. #227
    Sep 2002
    Chicago, IL
    6,397
    Post your file.
    We got this guy Not Sure, ...
  8. #228
    Jan 2012
    Cessnock NSW
    73
    I found it, finally, ..... Thanks guys
  9. #229
    Mar 2012
    8
    Is VCM Suite 3.2 compatible with Windows 10?
  10. #230
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by MickVette View Post
    Yes
  11. #231
    Jun 2015
    GVRD BC CANADA
    3
    in the new graph, histogram. Everything I now log under main spark timing and knock retard, the fuel trims and narrowband o2 all look messed up with zeros like this. the only one that's works like normal is the Wideband input I added. Not sure if I messed up the settings? I just downloaded todays version of the suite and same thing. The funny thing is if I load an old log from 2.24 the histograms all looks fine.
  12. #232
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Change "cylinder airmass (sensor)" to a different cylinder airmass PID. If you're running MAF only use "MAF Cylinder airmass (8 cyl)" instead.
    That should get it going.
  13. #233
    Jun 2015
    GVRD BC CANADA
    3
    Thanks so much! I pretty much got it now. Had to choose the generic sensors.
    Also another question. I am running speed density, in the scanner its all charting map in kPa vs rpm which is all fine and good. But in the editor when I'm tweaking the spark table, why is it cylinder airmass in grams? Can I go off the map instead? Just to keep thing uniform.
  14. #234
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by GIZZMotorsports View Post
    Right click, row axis, units.
  15. #235
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You can change units in either one.. easiest way is to right click on that table in the tune, go to row or column, units, change to whatever you need them to be to match scanner
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  16. #236
    Request: Can we please get the option to master enable/disable the "override parameter's" option please
  17. #237
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by NTIMID8 View Post
    can't you just check the box, Do Not Warn Me Again?
    or is that just per item?
  18. #238
    Sep 2002
    Chicago, IL
    6,397
    It's per session.
    A master "opt out" feature will be added eventually. The likely release version would be 3.6. We have some other big plans for 3.4.
  19. #239
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Math Parameters disappeared once again from the Tools>Math Parameter location.......
    Keith, I just downloaded the latest Public and Beta release and once again all my Math Parameters in Tools have disappeared....They are still in the Scanner folder but are once again wiped out in Tool. I just spent a half hour bringing them back from the last download because I have to open each various customers layouts to figure out where they go.....
    Ed M
    [email protected]
  20. #240
    Sep 2002
    Chicago, IL
    6,397
    Are you using multiple versions of VCM Scanner?
