Page 1 of 5 12345 LastLast
Results 1 to 20 of 97
Thread: Vehicle Controls & Special Functions
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Thumbs up Vehicle Controls & Special Functions
    VCM Suite 3.2 brings all new special functions to Chrysler support. Located within "Controls and Special Functions" in VCM Scanner 3.2, you will notice even more controls & special functions than before
    New functions include1:
    • Throttle Relearn: Will perform a throttle relearn for vehicles equipped with ETC.
    • Reset All Adaptives:Resets all adaptives (fuel trims, etc.)
    • Clear DTC: Chrysler Specific DTC Clear. Recommended to use along with the standard "Clear DTC" in "Diagnostics and Info"
    • Gear/Tire Adjustment: Was in 3.0 as well. Change your tire size and/or adjust gear ratios using this special function.
    • Traction Control Disable: Will disable Traction Control. Depending on the vehicle, you may need to do this after every key cycle. (Off-road use only)
    • Traction Control Enable: Re-enables traction control after you have disabled it, if it doesn't re-enable on it's own.
    1(Available functions may vary depending on what your vehicle supports)(Currently only for 2007+)
    Mar 2015
    7
    Will this work on a 2006 charger 5.7?Updated and don't see any of these
    Sep 2011
    Portland, OR
    523
    Awesome! Thanks
    How do you access that screen for the new functions?
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by wrc View Post
    Connect the vehicle to VCM Scanner and press the button for Vehicle Controls & Special Functions. (it looks like a green power button on the toolbar)
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by chargerman View Post
    If the Charger is equipped with a NGC3_CAN PCM, then not yet but we will look into it shortly.
    If the Charger is not equipped with a NGC3_CAN PCM, then these will not be available.
    May 2015
    1,908
    Guessing same issue for me, my 2006 SRT8 300C is equipped with NGC3_CAN. Also still waiting for the fix for gear ratio change, does not work on my vehicle, emailed support about it on June 7th, have not heard anything yet, still have Diablo married to computer to make the change. Ticket ID: 39567
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by 06300CSRT8 View Post
    Aware of the ticket. We are working on it but have no ETA for the solution on that.
    Quote Originally Posted by Mark@HPTuners View Post
    I just tried as instructed and I did not find the new functions. I have a 2010 Jeep SRT, if that makes a difference.
    Jun 2014
    36.1094, 115.1781
    432
    If you connect to VCM Scanner and click on the green power button, a window should pop up, even if it's blank. Email support with a VCM Suite Infolog and a screenshot of the screen that pops up.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,022
    awesome guys, glad you guys take customer suggestions seriously
    a++++++++++++++++++++
    The all adaptives reset will come in handy when tuning
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Mark, where would the green power button be located. I do not see one???
    May 2015
    1,908
    Its located in the scanner, top menu of buttons, right next to the engine with lightning bolt orange button. See screen shot, its not green in my screen shot because im not connected to the car.
    OK, I found it. Thank you.
    Jun 2014
    36.1094, 115.1781
    432
    Just a quick update on these features for CAN Based NGC3 PCMs....
    1. Reset All Adaptives is Now Available
    2. Clear DTC is Now Available
    3. Traction Control Enable/Disable needs to be tested by a user***
    4. Still looking into Gear/Tire Adjustment solution.
    ***If anyone would like to test "Traction Control Enable/Disable", please email support. Make sure to inform support that you would like to test Traction Control Enable/Disable for Dodge NGC3_CAN equipped vehicles. Make sure to include a VCM Suite Infolog and your .HPT file in the email.
    Tuner Pector55's Avatar
    Nov 2015
    Dover, PA
    186
    Thank you very much. This made disabling traction control very easy for a dyno operator not familiar with the modern hemi.
    2013 Dodge Challenger RT Plus - Shaker
    Tuner in Training 06charger's Avatar
    Nov 2015
    Arizona
    14
    Talking
    Thanks for all the hard work on the older ngc3's.
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    532
    Resetting the adaptives'? Is this something we should do periodically? I would like more info on this.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Quote Originally Posted by 2therock View Post
    Yes, I was going to ask the same question.
    Feb 2006
    South Carolina
    1,525
    It's useful when working on your VE table since the fuel trims don't reset after a flash. Resetting the fuel adaptives lets you start from "zero" for each tuning iteration.
    Jaime
