2013 Dodge Challenger R/T 5.7 Auto 5
Mods - 392 intake, PnP heads, cam, long tube headers and 3" exhaust
I have good flow and no knock so I've been bumping up the spark. It seems I have hit a wall and something is preventing it from going any higher so I'm trying to understand what tables the spark follows.
Starting at the WOT base, what else comes into play?
I see there is a thermal parameter for exhaust overtemp conditions - took that out of play
I assume it looks at the conditions for Hot and Cold spark (ECT) - my hot spark ref is 248* and that table does have a -1 in the areas where it won't go up any further but I'm only off .5 in some places and 1.5 at the top.
I assume it looks at the conditions for Barometer and references the Baro table. I have the bottom rows zero'd out so I don't believe that is the problem.
IAT spark is all 0's so that's not it.
MBT spark is the same as WOT spark so that shouldn't be the problem
Min and Max Spark state they are since start and the WOT runs are maybe 15 min after start so I didn't believe they were related.
Any tips on the conditional flow?
