Thread: Spark tables not doing was is commanded
    May 2006
    19
    I raised the spark tables for WOT and does not goes to the commanded value. I runing with race gas to avoid any pinging.
    - raised the value on the WOT Base an PT Base
    - Less timing on the IAT Spark
    - Throttle Rate Spark table moved to 0
    - Knock Threshould disinterested the knock sensor
    Eg I commanded 26 grades at WOT and I'm seen 20 grades
    Any ideas
    Nov 2007
    MI
    686
    paste a scan and tune or you probably wont get a response
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
    May 2006
    19
    Thanks you got a point
    Ortega(Mod17).hpt
    Hellcat Datalog 5.hpl
    This are the cat .hpt and log file any help will apreciated
    Apr 2014
    706
    Looks like it's staying in closed loop control even when you have the pedal matted. I also notice you're not logging aircharge, so it's hard to reference the tables without that variable.
