Results 1 to 10 of 10
Thread: 2013 Ford F250 6.7 MAF
    Jul 2016
    20
    Am I missing or looking over it or is the MAF table missing ?
    I am trying to scale the MAF for a new 5" Intake but can't seem to find the table.
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    So far I have not played with even looking at what the tunes look like since I don't have access to them. Can you post yours and I'll poke around?
    Oct 2007
    Crawfordville, FL
    2,584
    I didn't add the MAF table. The fueling is not based on the MAF readings. Is the truck not running properly?
    I can look into adding this if you feel it is necessary.
    Eric Brooks
    HP Tuners, LLC
    Jul 2016
    20
    Needing the MAF table due to some aftermarket intakes needing additional MAF scaling.
    When adding the 5" Intake some of the trucks have an issue with the MAF going out of range and causing a "LIMP" mode feeling. Which causes the truck to run lower boost and also affect the transmissions operation.
    Potential Tuner blackhaze's Avatar
    Jun 2016
    GA
    6
    Adding the MAF table would most certainly help me out as well.
    Oct 2007
    Crawfordville, FL
    2,584
    Please send an email to support and request the parameters added.
    Eric Brooks
    HP Tuners, LLC
    Jul 2016
    20
    Sent everything in to Support, also sent in the file that was giving me a Checksum Error.
    Jul 2016
    20
    Still no response back on the MAF Tables.
    Oct 2007
    Crawfordville, FL
    2,584
    MAF tables have been added and will be in tomorrow's release.
    Eric Brooks
    HP Tuners, LLC
    Jun 2016
    GA
    6
    Thanks Eric! Now if only I could get some some help on setting up Monitor pids on the scanner so I can datalog more.
