Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 98
Thread: Vehicle Controls & Special Functions
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by 2therock View Post
    Resetting the adaptives'? Is this something we should do periodically? I would like more info on this.
    Quote Originally Posted by wrc View Post
    Yes, I was going to ask the same question.
    Exactly what ElecTech said. It is very useful when working on your VE tables as both your LT and ST Fuel Trims will start back at zero every time you reset adaptives. Otherwise, there is no need to reset them periodically as you are just driving your vehicle day-to-day
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by Mark@HPTuners View Post
    Just a quick update on these features for CAN Based NGC3 PCMs....
    1. Reset All Adaptives is Now Available
    2. Clear DTC is Now Available
    3. Traction Control Enable/Disable needs to be tested by a user***
    4. Still looking into Gear/Tire Adjustment solution.
    ***If anyone would like to test "Traction Control Enable/Disable", please email support. Make sure to inform support that you would like to test Traction Control Enable/Disable for Dodge NGC3_CAN equipped vehicles. Make sure to include a VCM Suite Infolog and your .HPT file in the email.
    Traction Control Enable/Disable is now been tested for CAN based NGC3 and is available in the latest 3.2
    Nov 2015
    St. Louis MO
    188
    any chance we can get knock for or any kind of enhanced pids for NON-CAN NGC3 pcm?
    Apr 2014
    722
    Quote Originally Posted by Scottyb_288 View Post
    Knock and InjPW would be amazing...
    Nov 2015
    St. Louis MO
    188
    Yes they would. At least then i could stop using my diablo.
  6. #26
    Does the 'reset adaptives' also reset the transmission adaptives, or strictly engine side?
  7. #27
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by The_Bishop View Post
    Should just do engine adaptives.
  8. #28
    May 2011
    3
    the ngc4 ecm on the 2009 challenger does not have any of these features on the scanner. I this coming soon?
  9. #29
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by big steve View Post
    NGC4 is supported. Email support. Include a VCM Suite Infolog and a .HPT file with your email.
  10. #30
    Tuner in Training Awd1990tsi's Avatar
    Feb 2016
    Toledo, Ohio
    18
    2009 Caliber SRT4 isn't showing any of these, just updated the software. Is the caliber not supported for these? Or do I need to email support?
  11. #31
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by Awd1990tsi View Post
    The Caliber uses a vastly different ECU then the rest of the Chrysler lineup so these are not supported at this time. Please email support with your file and we can look into getting whichever of these the Caliber supports added.
  12. #32
    Senior Tuner Norris Motorsports's Avatar
    Mar 2006
    Kuwait
    1,587
    Thank you guys @ HP Tuners!
    Norris Motorsports
    Remote Tuning Services available for
    Mercedes - Audi - GM - Dodge
    Whatsapp: +965-55446651
    Email: [email protected]
    Instagram
  13. #33
    Mar 2015
    24
    I have read every dodge thread there is, as I just purchased the pro suite for 09 RT Challenger. Hope I wasn't to early in spending my money with a bunch of stuff that's not supported and don't work.
    FT
  14. #34
    Jun 2014
    36.1094, 115.1781
    431
    Quote Originally Posted by FlatTop View Post
    FT
    What are you concerned about that may not work? As far as these functions in this thread go, the 09 Challenger uses an NGC4 and supports these functions.
  15. #35
    Is there a way to check for the Readiness Codes for the emissions systems??
  16. #36
    Feb 2006
    South Carolina
    1,525
    Just poll for DTC's and they show up at the bottom of that window.
    Jaime
  17. #37
    Quote Originally Posted by ElecTech View Post
    I will check that. Thanks
  18. #38
    Nov 2014
    Moscow, Russia
    22
    First of all - HPT team is awesome. Guess there where something like 5 failed Chrysler and Dodge reads in last couple months, in all cases it took two days to add new definitions to new program release.
    Money for HPT well spent for sure.
    Got a question though.
    Any chances of Tunerlock support for gas Dodges/Chryslers?
    Flashed a Hemi yesterday, didn't notice such an option in Write drop down menus.
    '03 Topkick C5500 LB7/A5
    '04 Silv cclb 2500HD LB7/A5
    '10 Ram ccsb 2500 6.7/A6
  19. #39
    Jun 2011
    Tucson, AZ
    295
    Quote Originally Posted by Vlad0380 View Post
    2016 Hellcat Challenger, automatic, black on black with brass monkey wheels
    10.13@ 140 DA 5000 feet
    2.75 pulley, tune, drag radials. 10 percent lower od crank pulley, 1050 ix. off road mid pipe. tune
  20. #40
    Jun 2011
    Tucson, AZ
    295
    I just purchased a 16 Scat Pack. I have not tried to read the tune from the vehicle yet. I was told that I would not be able to read and make changes on this tune. That I would need to have the ecm professionally unlocked or buy another ecm from Diablo or another vender.
    Also I looked at the tune repository for the late model Challenger. It is totally different than looking at a tune for a G8 which I still have.
    Are there books out there regarding tuning a Challenger which would help my understanding of things?
