I put together this template including speed, lean angle and G-forces. The custom lean angle indicator shows negative values for the left lean angle and positives for the right lean. However the widget bar movement starts at -60. How can I make it start from 0?
Also I added maximum values for each widget but the text is not aligned correctly to the square box. How do I right justify the text in the green boxes?
