07 Charger RT AWD log and tune (few questions)
first drive.hplread.hptmy charger.Layout.xml
So I had to make a tire size adjustment to the wife's charger... After doing so I decided to go for a drive and log. Looking at the low kpa fuel trims and the knock I decided I may want to make a few changes. Figured while I was in there I'd make a few more ponies.
The log files a bit lengthy, with 2 wot pulls at the very end. Its a 07 charger rt awd stock other then a k&n drop in.
I noticed a few blips of knock with no coloration to the knock threshold tables or a trans shift. Was wondering what would have caused the timing retard. I did get a message saying the os was old and this was a new starting calibration. Were the knock sensor settings changed from the older os's?
Also noticed that the commanded lambda was much richer then this calibration. I assume its cot but this calibration I'm looking at has the cot temps maxed out. Did they disable cot in the later os's?
Thanks in advance.
