Results 1 to 5 of 5
Thread: 2005 Pontiac Grand Prix wont read car
    Apr 2015
    Hello all,
    Been on the forums here and there for a while. I rarely post, however recently my wife got a 2005 Grand Prix SC from a local. I tried reading the file and it starts to read then immediately fails the read and then attempts 3 more times until it stops. It spits out a phrase like "failed at loc. 8000.....or loc 3300 and each time does something different. The car has 99,000 miles and runs perfect. Has 2 BCM codes 1 theft system not programmed and another relating to the windshield wipers.
    I have read briefly about doing a write entire from a tune online.....
    Could any please chime in with their thoughts?
    Thank you
    Advanced Tuner Dr. Nopps's Avatar
    Jan 2011
    I'm proudly a successfull stalker of an honor roll student!
    368
    Try pulling out the radio fuse before you connect to the vehicle, then attempt to do your read. Don't put the fuse back untill you're all done and the car is definately off. This may help out, might not do anything different at all. Good luck.
    Apr 2015
    I pulled the fuse and also updated my HP software and it all works now!!
    Thank you for the response Dr. Nopps! I appreciate the help
    13,609
    2004+ grand prix's are very picky that's for sure.
    Glad I never had that problem with my 2000 GTP.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    that's strange. I read and wrote to my 2004 GP many times no problems, however this was with 2.24 not 3.x.
    ZL1 Wheels/Tires
