Thread: E67 flex fuel sensor activation
    May 2015
    21
    I just installed a flex fuel sensor.
    Pink wire to 12v ignition
    Black to ground
    White to pin 5 of J1 (blue) ECM plug.
    I get remote tunes as I am a long way from tuning on my own.My tuner is unavailable. I am not getting a reading from my sensor when I datalog. I am very confident I wired the pin properly. If anyone has a moment can they look at my tune to make sure everything is correct for it to work?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Enabling the sensor would be an obvious place to start...
    fuel-->open/closed loop, Flex fuel sensor "enable", sensor type "sensor"
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    May 2015
    21
    Thank you.^^
    I saw that in the tune and just didn't have the confidence to change it without a knowledgeable 2nd opinion. I was told the new tune was flex fuel ready.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah looks like they missed those. I didn't check but make sure the stoich AFR table is setup correctly also
