Results 1 to 6 of 6
Thread: Throttle Position
    Tuner R8SVton's Avatar
    Aug 2007
    Wollongong, NSW, AUST.
    162
    Throttle Position
    Hi guys,
    Did a log with version 3.2.146 and found the THROTTLE POSITION to be reading 39%.
    Cheers
    TJ PERFORMANCE
    2014 HSV GEN F R8 SV Enhanced (LS3 340KW)
    6 Spd Manual
    Tuned @ 281RWKW/629Nm with OTR and 100cell CATS only.
    Aug 2007
    162
    Must be normal if no replies
    TJ PERFORMANCE
    6 Spd Manual
    13,614
    Remove the channel and re add it, then see what happens.
    On GEN 4 computers, full throttle should be 87-88% and not stay stuck at 39%.
    Aug 2007
    162
    Thanx for your reply,
    before I updated the software, full throttle was 87-88% and when updated it reads 39% full throttle.
    TJ PERFORMANCE
    6 Spd Manual
    Banned
    Oct 2016
    379
    Quote Originally Posted by R8SVton View Post
    I wanted to help, but didn't see your question or point. You just wrote your TPS was reading 39%. Like - and? Your speedo is also reading 113km/h, MAP 98kPa... in the pic. It looked like you just accelerated and held the throttle open at 39%.
    So the problem is your TPS maxes out at 39%, right?
    Try a different TPS gauge.
    If all of them don't work right, make a custom one in Math Parameters.
    And try what 5FDP wrote.
    Aug 2007
    162
    Hi 5FDP,
    I removed channel and re add it as you suggested, the news is it went from 39% full throttle reading to 61% full throttle reading. So its improved a little.
    TJ PERFORMANCE
    6 Spd Manual
