Yeah, that's weird
Yes
Has anyone here had the amount of User defined math parameters change in the scanner before? Yesterday I was showing the regular amount of 20. Today I am only seeing 10. Same software on my desktop shows the 20.
I have tired uninstalling and reinstalling the software. But it still remains the same. I even tried an older version of software.
The list is dynamic, and will show more slots as you use them.
We got this guy Not Sure, ...
Thanks for the reply Keith. The strange thing is that I was using 10, 14 & 15 last night.
When I fired up the scanner to do some logging this morning a few of the histograms/graphs didn't populate because the math parameters weren't in the list anymore that I used last night.
I took the VCM Scanner.cfg file from my desktop computer and put it onto my laptop and all seems good again.
I'm just puzzled as to why they disappeared.
So what you are saying is that if I use up all 20 user defined math parameters currently listed on my computer the software will make more slots available?
Yeah, surprised me too a while back.. adds them as needed.
i know that the maf hz scaling would auto populate on the 2.24 scanner setup. What happened to this feature in 3.2? {as far as the hz range, 0-12500 ranges. each ecm has a different range it works in and 2.24 would populate this accordingly.}
93 Ranger. 5.3 D1X. 1069hp.
It's one copy/paste operation, very easy.
It only worked for a small number of ECM's in 2.24 so it was not carried over to V3 and newer.
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
i know, it was convenient though when going from an lsj to an ls1 it would swap it.![]()
Weird, doesn't show up for the stock 2009 Z06 file I have either
Wonder if you just need to send it in for them to add that OS?
2004 GTO.hpt
Can anyone tell me if this file (OS 12587604) has full Flex Fuel capabilities with this upgrade? I need a good "working" DBC Flex File for the P59 PCM.
I got into the vcm editor 3.2 and realized we no longer have access to turning dtc off and on. Am i missing something? Did it get moved?
Download 3.4 and try again.
It just came out.
Also you must be in advanced view under the edit tab to see everything. You can still disable DTC's, nothing was removed.
Edit, view, advanced.
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
