Thread: Motec LTC (Lambda To Can) Wideband controller and MVPI-Pro compatibility ?
    Feb 2011
    24
    I've seen the work done by dr.mike (nice job BTW) with the Aem can bus wideband.... curious if the Motec LTC(D) would work as well. We're using a LTCD with dual Bosch 4.9's on our Spec TT feeding the Motec Display loggers, and are limited by class rules to the stock GMPP LS3 ECM's. The LTCD has configurable CAN addresses and messages, does anyone have any info or specs on how to get the MVPI-Pro to be able to log the can bus wideband outputs? Would be awesome if this was possible!
    Aug 2018
    43
    bump
    Jul 2023
    4
    Another Bump. I have a new LTCD sitting here as well that would be handy to use with VCM Scanner if possible.
    Mar 2024
    Sydney, Australia
    8
    Quote Originally Posted by Kevin@KMR View Post
    Yes you can use the Motec LTC to bring Lambda in over can using the prolink cable on a mpvi3. I am currently doing this.
    We did have to slow the baud rate on the LTC down from 1000kbs (stock motec speed) to 500kbs which is the MPVI Speed.
    Depending on wiring length you may also need a terminating resistor.
