Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
Ahh yes.. undo as well is on the todo list..
We got this guy Not Sure, ...
Higgs,
Wat u need to do really is log the % error between ur maf and log also ecu desired maf also the same thing for measured map vs ecu desired map and apply the changes i will be sending hptuners support the tables to be added to allow the ecu to use measured map and measured maf instead of back calculating and chasing it self
It's throttle desired airflow vs maf airflow (I log both in g/sec)
And
Throttle Desired map vs actual map
I log desired airmass and compare it to actual as well...
Jarrah thinks for getting that added
14 Gen 5 Viper
thanks guys, very cool on all accounts
Very very cool guys. Thanks!
Tuner at PCMofnc.com
Seems like we might be making leaps and bounds now - thanks Jarrah - big plus to you on all of this! Not to mention HPT and everyone else...
Do you also log these errors to dial in the driver demand tables or do you just dial them in more for pedal feel?
~Greg Huggins~
hey keith, check your pm's!
93 Ranger. 5.3 D1X. 1069hp.
Area47, it's best to post tuning related questions on the forum.
Also, I don't have all the answers.
I am getting an error when attempting to Extrapolate Coefficients.....
14 Gen 5 Viper
14 Gen 5 Viper
Please remember that this feature is in active development. Bugs are fixed and features are added to it every day.
Keith, can you make it to where it modifies the b,c and d tables too since it always seems that these tables are the same... All it modifies right now are the "A" tables...
~Greg Huggins~
You could arbitrarily build an equation to calculate TQ based on airflow and rpm to give you somewhat of a linear basis to start from. Until we can get plugs to input the data from the dyno it's going to be difficult to calculate it.
Me personally I plan on manually inputting TQ values from various points using steady state on the dyno and interpolating the rest from there.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
Beta version 3.5.72 is crashing every time a file is edited and attempted a save on a file I was working on. It destroys the file as well. Sucks, had to redo that file completely.
www.crawford-racing.com
Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
Emailed support twice and haven't gotten an update. I have a modded Z06 A8 on the dyno right now and would love to play with this.
HP-Unlimited Tuning and Custom Fabrication
Houston area performance parts dealer
MD800 Mustang Dyno 713-560-3889 Taylor
2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
Just killed my file with 3.5.73
Going to About it says Version 1.8.1....
Dang good thing I'm not modding files tonight
14 Gen 5 Viper
