Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 198
Thread: Torque Model editing functionality now in beta!
  1. #81
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    Actually getting to play with this on the dyno right now. 2016 C7Z A8 upper lower pullies, H/C, Ported blower, headers, intake, meth, and nitrous.
    First thing I did was smooth the areas I was seeing throttle closing and it definitely helped out there if not solved it completely, but having issues beyond 6350rpms. Logged maximum engine tq follows same curve as actual but zeros out at 6350rpm every time.... At that point dyno shows Tq and hp tanking. Wonder if this going beyond bounds?
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
  2. #82
    Aug 2009
    Calibrating
    3,378
    Quote Originally Posted by silverbullet08 View Post
    Have a log or a screen shot? What is zeroing out Maximum Tq?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  3. #83
    Dec 2009
    Houston, TX
    453
    Yes maximum tq. Didn't save the last run. But it has been pretty consistent so I'll screen shot it on the next run.
  4. #84
    Aug 2009
    Calibrating
    3,378
    What is delivered or engine tq doing?
    14 Gen 5 Viper
  5. #85
    Dec 2009
    Houston, TX
    453
    Having issues getting a the file to attach "stupid new laptop"
    Delivered Engine Tq holds 640 across the board till 6575 then tapers to 615 at 6750
    Engine Tq is following its steady curve through the pull then mirrors delivered engine tq from 6500 to 6750
    After looking at this more it looks like throttle is shutting again only when maximum tq zeros out
  6. #86
    Sep 2002
    Chicago, IL
    6,397
    New beta up with the following changes:
    Intake cam angle changes seem to work now.
    Exhaust cam angle support added.
    Copy/Paste now works.
    Undo Last/Undo All seems to work
    Smoothing/Interpolation while unlinked is fixed.
    Column widths were too short
    The only thing that seems to be left is the ability to remember limits/ranges/preferences per tune/file.
    We got this guy Not Sure, ...
  7. #87
    Mar 2010
    Texas Hill Country
    3,299
    Great!
  8. #88
    Dec 2016
    11
    Good deal!
  9. #89
    Tuning Addict
    6,873
    Very nice Keith... Is making the coefficients the same in all 4 tables coming in the future Now I've just got to start really messing with this to see how the best way to use it is
    What about the other missing tables - will these be available soon? Last I heard Jarrah didn't get around to getting one of them for you, but sent you the two more important ones?
    Thanks Again Keith
    ~Greg Huggins~
  10. #90
    Mar 2010
    Texas Hill Country
    3,299
    3.5.85 won't let you copy/paste from, for example, Airmass to E85 Airmass if you want to copy all of them Linked. You have to go one by one but when you switch between them you lose each paste. You can copy each spark table individually to excel then individually to the E85 tables but it won't let you extrapolate coefficients after pasting. You can manually edit a cell after copy/paste and the extrapolate button will activate.
  11. #91
    Sep 2002
    Chicago, IL
    6,397
    You can't copy all of them linked.
    I will fix the second bug.
  12. #92
    Aug 2009
    Calibrating
    3,378
    What I've been doing is going from say airmass to e85 airmass is copy the airmass coifficients and paste them into the E85 airmass then reopen the virtual tq and adjust my E85 airmass based off my airmass tables..
    Probably should be an easier way but that's what I've been doing
    14 Gen 5 Viper
  13. #93
    Mar 2010
    Texas Hill Country
    3,299
    I tried copying straight from the Airmass and MAP coefficient tables to the E85 Airmass and E85 MAP tables, which would have saved me from using the Editor and copying each table individually and each cam angle (times each table) individually but it appears only the MAP tables copied over. The Airmass tables didn't copy the cells properly so I had to use the Torque Editor.
  14. #94
    Dec 2016
    11
    For support. More than a day ago, I asked for a 3.5 version. Still do not have. Application 62485. The car is waiting. Please do.Do not see join date, its my new account. I have 2 HPt vcm.Thanks.
  15. #95
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by vcm300 View Post
    Many businesses are closed on Saturday and/or Sunday to spend time with family, sleep, and wash underwear.
  16. #96
    Dec 2016
    11
    Now i have. Thanks for support!
  17. #97
    Dec 2016
    11
    Quote Originally Posted by Higgs Boson View Post
    A lot of work, so do not even notice what day of the week Sorry
  18. #98
    Mar 2010
    Texas Hill Country
    3,299
    i forgive you ;-)
  19. #99
    28,303
    50 lashes with a wet noodle
  20. #100
    Tuner in Training thewhip's Avatar
    Mar 2015
    USA
    17
    Been playing with this table, no question it does help. But, separate from just smoothing (some are not bad, some are really rough), should we generally be telling the PCM more or less torque? As this seems to be a function of there calculation, does telling it more torque for a given spark/airmass increase possible airflow demand to meet that torque?
