Results 1 to 14 of 14
Thread: How to ADD in evap?
    Dec 2016
    Rochester NY
    27
    How to ADD in evap?
    I'm doing a swap in an old car and I'm starting to think about fuel plumbing. I have a fuel cell and was just going to vent to atmosphere but now I'm thinking I should hook up a canister and purge valve. I only have an engine with harness, is it as simple as getting and wiring in the evap canister purge, evap canister vent, and fuel tank pressure sensor? Is there anything else I need to be aware of? What is typically done to remove those that I need to be sure not to do?
    Oct 2013
    550
    Firstly, good for you. We install EVAP systems and catalytic converters on every LSx conversion that leaves the shop - whether it is a 1930's Ford or a 1970's Chev. This affords peace of mind to the owners - they can drive them anywhere without a second thought, and can also sell / register them anywhere without issues.
    The specific answer to your question depends on what controller you are using (PCM / ECM).
    The 1999+ LSx EVAP systems had two primary subsystems, as you pointed out. An EVAP Purge Solenoid (mounted on the intake manifold) and an EVAP Vent Solenoid / Fuel Tank Pressure Sensor mounted in (or adjacent to) the fuel tank.
    In an older conversion, like a vehicle that was originally equipped with a Fuel Vapor Storage Canister (Charcoal Canister) between the fuel tank and the engine, you only need the EVAP Purge Solenoid from the LSx system.
    The Charcoal Canister would have been originally connected to a ported vacuum source at the base of the carburetor. Plumb this rubber line to the EVAP Purge Solenoid, adjust the tune / DTCs as necessary, and you are good to go.
    Dec 2016
    Rochester NY
    27
    Thanks for the reply. When I said older I really meant older, 1965 to be exact, haha. There isn't anything from the original car that can be used. The engine is a 98 but I am converting to a 0411 PCM.
    I am going to try to source the solenoid and pressure sensor from the guy I got the motor from, otherwise will head to the junk yard and get the parts from a 99-00 gm vehicle.
    So long as I hook up those 3 parts to the PCM and relevant fuel tank and intake ports then it will work as intended?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    you also have to have a fuel tank pressure sensor, and the fuel level sensor has to be correctly programmed into the pcm. The system will only draw vapors when between 1/4 and 3/4 tank.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Oct 2013
    550
    Different controllers may use different EVAP diagnostics. With the P01, the requirement for the fuel level to be between 15% and 85%, is the range in which the Fuel Tank Pressure diagnostics will be active (actively looking for a leak in the system).
    I don't believe the actions taken (when any EVAP related DTC is set) is to disable any part of the EVAP system. The rational seems to be to get at least some of the fuel vapor into the engine.
    In a retrofit application (like this 1965 model) you can make the EVAP system as simple, or as complex, as you like. The goal is to reduce the amount of fuel vapor vented into the atmosphere.
    Dec 2016
    Rochester NY
    27
    Quote Originally Posted by mbray01 View Post
    Good to know. The fuel cell I am using came with a 0-90 ohm sending unit.
    Dec 2016
    Rochester NY
    27
    Quote Originally Posted by Jon S. View Post
    What parameters are tunable? I do plan on (eventually) using all 3 pieces.
    Dec 2013
    Slidell, La.
    1,018
    The purge solenoid will not operate if the ecm reads an empty or a full condition, this is done to prevent raw fuel being drawn in after a fuel fill
    therefore if the level sensor is not hooked up and properly programmed it will not purge, unless you specifically wire it to turn on. The ecm will not do it. If the level sensor is not hooked up it will read either full, or empty based on the ecm calibration
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Oct 2013
    550
    That does not seem to always be true. A broken fuel gauge does not always disable the EVAP system.
    GMPP calibrations that were OBD-II compliant, had the EVAP Purge Solenoid (and DTC) active, while the EVAP Vent Solenoid, Fuel Tank Pressure, and Fuel Level were not active.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    The vent valve & fuel tank pressure sensor are just for the pcm to detect if there is a leak in the system (bad fuel cap or purge line etc).
    On a retrofit application, you just need the purge valve hooked up to the canister & set the vent valve, pressure sensor & small & large
    leak codes set to no error reported.
    Russ Kemp
    Nov 2014
    Utah
    60
    I just did a LM7 5.3 swap in a 01 Mustang and after reading this thread I'm not sure what to think. I simply plugged the tube to the purge solenoid on the motor into the stock Mustang canister. Will this work and purge the canister? Or does it have to have tank pressure and level inputs to the PCM to tell the solenoid valve when to open? The stock Mustang tank doesn't have these.
    Jul 2015
    927
    Does the fuel level sender go directly to the PCM or go through a BCM first?
    Dec 2016
    Rochester NY
    27
    I'm pretty sure the PCM has an input for fuel level, haven't looked into it in a while though.
    Feb 2022
    Reviving this old thread. Can anyone confirm if the purge solenoid can be used without the vent/pressure solenoid/sensor? Thanks!
