Using HP tuners scanner I verified the computer is commanding TCC on at 9mph. The converter is locking up at 9 mph and then unlocks as you slow down at 9 mph. I don't understand how this is even possible? Any help would be great! Larry
Is everything stock?
Any trouble codes or recent work the vehicle?
Post the tune file and logs of the issue could help.
It's a 96 suburban with a conversion injector and ignition conversion done to it. The computer shouldn't even be able to command TCC in first gear to my understanding. Not sure which direction to go. Any help would be great. The speedo works fine, the scanner is showing the proper speed compared to the speedo as well. Larry
Here is the tune, how do you retrieve the log?
Does the speedo read correctly? The tune is setup to lock the TCC at 48-55mph in 3rd, nothing for 1 or 2. Does it shift properly otherwise?
Open VCM Scanner, connect to your vehicle, add any additional parameters to be logged, and start logging. I'd want to see the TPS, RPM, TCC mode, and any additional TCC ones.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
