I have a 2014 Camaro SS LS3... Have all tq. mgmt. disabled already, fueling/timing adjusted, tq. settings set to 8191 where desired, etc.
Throttle response has improved some, but still looking for more..
So, in my searches here, I've found out about adjusting the Cylinder Charge Temp Filter settings, fuel cutoff settings, transient fuel settings, etc.. and those have helped as well..
Now I come to the Airflow - Electronic Throttle - Desired Throttle Area Map-A table.. and have read about some issues with adjusting this.. and have also read where some have adjusted it and have had no issues..
I've also read about this table on the other "E" forums, and it has been said that as long as you don't change the first and last rows/columns of the table, you can change center values to whatever you want and it will be fine..
And i think it was on these forums somewhere that someone said they moved all values over 1 cell to the left - i.e. where the 1 value starts in a column, move that value over to the left one space, and make that 0 column be all 1, then change 1 column to 2's, 2 column to 3's, etc etc.. shift them all over 1 column to the left..
So, while I know this will help to improve throttle response more, I definitely don't want to brick my ECM haha..
What is it's relationship to the TAC module, as far as how much you can adjust this table and NOT have any issues with the TAC and not throw codes/lock the ecm?
Has anyone had success in modifying this table with no issues?? and by how much??
Thank you in advance!!
