i would share my result of modif chaarger 06 rt
- 6.1 CamShaft
- 6.1 Intake Manifolds
- ARH 1/7/8
- ATI 10% OD Pulley
- ProCharger P1SC-1 @ 9.5lbs
http://imgur.com/4QOmFuM
dyno 476 hp 552 trq.hpl
the issue here is the engine torque higher than engine hp .. is that normal ??
second : on the dyno _ max boost 8.5 lbs @ 6200 rpm
on the street _ max boost 9.5 lbs @ 6200 rpm
should i see more power with more boost ??
