Hello All.
This is an LNF with a BorgWarner 6258 and I am getting a VE spike around 22psi.
I been reading all the how to threads for a few months and followed Mike M instructions to a T and used his Base Tune to get started.
to MikeM since his instructions got rid of the pesky 3.7 degress that showed up everywhere.
The car has no knock and the trims are on throttle +-2 with the LFTF disabled (Idle needs a bit of work).
However I cant get rid of the VE spike, it spikes to the max (67.9 i believe).
Would this be an hardware issue, such as a leak on the charge pipes. I have done a boost leak test but perhaps the leak is only present above 22 pounds.
