Page 8 of 8 FirstFirst ... 45678
Results 141 to 155 of 155
Thread: Multiple problems with version 3.4 Pleae help
  1. #141
    Tuning Addict
    6,888
    Keith is the fix being applied to the 3.4 version too? I've been telling everyone having this issue to request the beta since I wasn't sure... I've only been doing short logging sequences up until today, but it didn't freeze up at the usual 13 minute mark yesterday - Corey said he ran my bad layout for 2hrs straight without issue, so I'm sure it's fixed...
    Thank You Keith for getting it straightened out, Thank You Dan for helping out on this
    So when can we expect the Whipple Decrypter and Ford VVE
    Dan, You should also really like the beta - unless I'm just losing my mind now - which is possible - I swear the pages in the editor even load and respond quicker - not to mention the other built in additions...
    ~Greg Huggins~
  2. #142
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    I ran the Beta 7hrs 59mins and it locked up, but this was with the setup that ran 12-30mins max... so it's fixed!
    ZL1 Wheels/Tires
  3. #143
    Sep 2002
    Chicago, IL
    6,397
    GHuggins, 3.5+ only.
    We got this guy Not Sure, ...
  4. #144
    Tuning Addict
    6,888
    Don't know what you changed Keith, but scanner so far appears to be working a heck of a lot better all around even as far as data acquisitioning goes - still shows blank cells on startup and leaves those cells blank even after hitting them again until you save, close and reopen, but no lock ups/hickups/glitches or so on thus yet...
    Much appreciated.
    Thank You.
    ~Greg Huggins~
  5. #145
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    Quote Originally Posted by Keith@HPTuners View Post
    I think your ticket is in the engineering queue for a definition update.
    Keith
    untill today the limits and the copy function in the editor still work not satisfactory! is that so difficult?
    its important for me. please fix that!
  6. #146
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by Auto-Hentzschel View Post
    Keith
    What's your ticket #?
  7. #147
    Sep 2015
    Schleid, Germany
    341
    #61547
  8. #148
    Sep 2002
    Chicago, IL
    6,397
    Reply to the ticket with the specific parameters you are having limit issues with.
    The copy issue you're experiencing isn't an easy fix. The copied tables should be close enough that it won't make a difference. If you're seeing large differences in the copy, please provide an example and details.
  9. #149
    Sep 2015
    Schleid, Germany
    341
    the copy function is not perfect, but it works.
    But try to raise up the limits (only in tabels) will not work. Use a 2016 Mustang GT file and try to set the value from 2 to 3 in the ECM32378 map. its not possible. The same is in all maps with limits. single scalars are possible to set above the limit.
    3.0 VCM editor work perfect with that.
  10. #150
    Feb 2010
    16
    Hi
    I am having a weird problem. Im using 3.4.89. I setup my layout and do a Save Layout As and everything is working fine.
    But when I boot up the Laptop the next day the Layout has reverted back to default. I have set it up 5 times now and have been very careful to save the layout but it always reverts back to default. Real pain in the ass! And Ideas what I might be doing wrong?
    Thank you
    Christian
  11. #151
    Jun 2008
    539
    Quote Originally Posted by Zo6 4 Me View Post
    Hi
    Thank you
    Christian
    I thought that was normal. I just click on layouts, recent layouts, select the last one I used.
  12. #152
    May 2017
    Sacramento California
    11
    Quote Originally Posted by Jason B View Post
    I had tried that but it only brought up the default.
    I figured it out. It looks like you have to click on the "Lock Layout" and then do a "save as".
  13. #153
    Sep 2002
    Chicago, IL
    6,397
    Hi
    Thank you
    Christian
    Do you have an older version of VCM Scanner installed that you're also using? That can cause what you're describing.
  14. #154
    Aug 2016
    Thunderdome
    389
    When I download the latest software, that encompasses both scan and edit or do I need to down two different files to load over the previous os?
  15. #155
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    VCM Suite download includes both
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
