Results 1 to 5 of 5
Thread: Why can't I lock my stall in TUTD mode?
    Sep 2011
    301
    Hi, I cannot for the life of me figure out why I can't lock my stall while in TUTD mode if my delivered torque goes over 300 ft/lbs.
    I tried hardcoding all non normal tables to lock at a low speed. It works as expected in sport mode, but not in TUTD. As soon as delivered goes past about 305 ft/lbs, it unlocks.
    Could it be the apply ramp rows? I noticed there the last row stops at 310 ft/lbs. Any help is appreciated.
    lock.hplg8-playing-mpg.hpt
    Sep 2011
    301
    Tried upping the torque rows in the apply ramp with no luck. This is puzzling.
    Sep 2011
    301
    I think the problem is that the TUTD tcc tables for wot are missing and it is going into wot mode at 300 ft lbs
    Tuning Addict
    6,896
    You tried raising your tap up / tap down release speed? It's setup to disengage at 100% throttle - I assume your doing this for tuning?
    ~Greg Huggins~
    Sep 2011
    301
    I was just sanity testing to see if any settings worked. 2nd was engage at 19 mph and release at 12 mph or less no matter throttle, so as soon as I hit 19 mph it does indeed lock, but I hit 300 ft/lbs and bam unlocked. It goes into WOT mode and that table is not in the editor. 2009+ pcms got rid of the WOT settings and just reference the one table. I don't think there is anything I can do, which is a bummer because I love TUTD for roll ons.
