Today's build of VCM Suite 3.4 has parameters added to control how the Active Exhaust system functions. I've had several requests for this over the past few months.
Eric Brooks
HP Tuners, LLC
My hero.... thanks for taking the time to make this happen bro.
this was, what I'm waiting for. Thank you Eric
Parameters added to the scanner for this as well, which will allow you to log the position of the active exhaust valve.
Eric Brooks
HP Tuners, LLC
Where do we download the update?
On your customer page like always.
Yeah I did download that for some reason the tables are not showing up. I will redownload it again.
Still doesn't show up any help would be great.
Here you go thanks
2017 GT350.hpt
Not showing for me either (focus rs).
Hello does it work for activating/parametering active exhaust of 2019 Mustang GT?
Hello,
I recently bought your MPVI2 tuner and licensed the ECM of my 2019 Mustang (4 credits) to activate my active exhaust retrofit (used oem parts). Although I see the active exhaust menu on my dash (using firscan as described in forums), and enabled idle switch, load switch and manual control using Hptuners, it is still not active. Is there anything else should I modify? Is is the right programming procedure?I have read on forums that people managed to activate it using HpTuners (Palm Beach Dyno did it for instance)Thanks for your help.
Maybe Eriv@HPTuners could answer that?
Eric@HPTuners I meant
Is this feature supposed to work with a 2020 Mustang GT?
Whatever I do with the active exhaust settings, they have no effect whatsoever. The AE behaves just like it did before. And if I try to scan the Active Exhaust Desired Position parameter in the VCM Scanner, it's always 0% no matter what I do.
I've wasted four credits for this.
Any suggestions as to what else I could try?
