My traction control acts goofy sometimes would like to disable it with a switch for that whole day or for ever. Can it be done?? Stock switch turns it off until car is started again.
Need a relay that comes on for a second after you start the car that replaces your factory switch. Nothing in software will fix the hardware...
Always Support Our Troops!
I have one of these for sale. Works perfectly, but I am selling the Vette and will not need anymore. www.laptrax.com $50.00 shipped.Originally Posted by Dragman
Rob
Viper GTS with TNT 250 shot
Grand National with High Boosting Turbo Power
Trailblazer SS 'HP Tuned' for Power Perfection
"I never met a power adder, or avatar I did not like"
ill take the labtrax if its still available
04 Z06-AFR 205's, LGM G5X1-E, LG long tubes, etc.. 458/423
05 Colorado Z71-Stock
I see the 1999 has the ETC TPS MAX table zero'd out. On my 2001 ZO6, I raised the oem table values to make the traction control less intrusive. Now traction control is my friend
Russ Kemp
so can the TCS be deleted all together or just reduced ?
