Steering assist is reduced. Please drive with care
I flash the stock tune after. Same
Reflash entire. Same
Unplug battery same.
Can someone help me ??
How long did you leave the battery unplugged for? Are you able to check for DTC's?
2 min the battery
no DTC.
message went away after a ride of 2hours
went back this morning
Mine shows the same thing every time I start the truck ever since I did the first read/write. Just never got around to emailing support...
2023 Ford Maverick 2.0T AWD
we email support and no one can help us.
i reveived the answer : nothing related to the read/write processus.
Did either of you two figure out the issue on your trucks of why the steering assist is reduced message was on?
Just so happen this just happened on the 2017 Silverado that I did the 6.2L manifold and throttle body swap on, then tuning on.
Nope. I have to clear it with the cluster button every time I jump in the truck.
Bumping this back up. Anyone find a solution? Just tuned a 2017 and it's been on ever since first flash.
It should have set a C0 (chassis) code.
I`m not sure that HP can read those codes?
Is steering assist actually reduced or you are just seeing a (errant) message with the warning the dash?
Don't notice any loss of power steering but who knows. I'll try and read the chassis codes with another scanner. Just ironic it happened after flash.
Did the speed limiter get maxed out during the tune?
Just a thought, but gen 5 does not like some tables maxed out.
I read there was a recall for 800,000 trucks by chevy for steering assist problems.. just a fyi
Thank you. The speed limiter was not modified in the tune.
still have the message
dont know how its happen
Just post the tune so people can look through it to see what was changed - otherwise just a guessing game...
~Greg Huggins~
In my situation, truck had a lost communication code with module. Cleared it with scanner and no more issues.
Happen again with a reflash of a modification
