Results 1 to 20 of 27
Thread: User Defined Parameter
    Dec 2008
    on the Dyno
    1,825
    Can we get a bit of an explanation on what this is? Is it global add-on for all OS's or is this a per tune add on?
    Located in Central Kentucky
    ShorTuning
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Beat me to it.... See: https://www.hptuners.com/forum/showt...ned-Parameters
    The $99.99 feature is a global unlock for all controllers that support User Defined Parameters
    Dec 2008
    on the Dyno
    1,825
    Awesome!
    ShorTuning
    I paid the $99 and I inputted the app key and I'm still getting definition failed to load error... does this only work on Chrysler apps or also gm?
    Owner of Cunningham Motorsports
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by rynez06 View Post
    The feature works on most controllers for GM, Ford, and Dodge. If you are getting the definition failed to load error like you see here:
    You still need to email the file and VCM Suite Infolog to support so we can support for the operating system in VCM Editor. Once the operating system is supported, then you can use the User Defined Parameters feature to add other parameters that you may need.
    Dec 2008
    on the Dyno
    1,825
    So we need to do an info log and send that along with the tune in to have support added? I also tried adding a few parameters with no luck.
    What if we don't have the car in front of us? Infolog of just the cable data good enough?
    ShorTuning
    Will it work for the slave OS on GM?
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by LSxpwrdZ View Post
    Let me clarify. To be able to use the user definition feature, you must first open an .HPT tune file in VCM Editor. When that .HPT file opens, it must open without a checksum error or a definition failed to load error. IF you receive a Checksum error and/or a Definition Failed to Load error when trying to open the .HPT file then you will not be able to import user defined parameters until the issue gets resolved.
    If the HPT file opens just fine in VCM Editor and you can see all of the parameters that we have defined already for that file, THEN you can go to User Defined Parameters and import your XDF files.
    Now how do you save a file as .bin?
    Quote Originally Posted by Mark@HPTuners View Post
    everytime I open the software I get this error.
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by yellz06 View Post
    Not at this time.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Sooooo when will some A2Ls get posted?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Do mods get a uh... free trial?
    Asking for a friend
    Dec 2010
    Richmond, VA
    40
    Can we have something similar to add logging parameters to the scanner?
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    Quote Originally Posted by BigCE View Post
    Curious as well. Is this something we're responsible for on our own or will support help us in obtaining a .bin version of a strategy we want to work on? Ford application by the way.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    So how do you develop these new parameters
    I am not afraid to admit I am a novice when it comes to burrowing any deeper than the provided parameter cells/tables. How does one find the magic decoder ring to determine what treasures are left uncovered beyond the current HP Tuners Editor. Do you have to have the actual executable PCM code to dissect further? I also understand this doesn't allow you to write new code so it is just open to new tables that will help.
    If there is an "Admission charge" or an initiation to the club, what is it? If not, how does one go about using this new feature. Is it possible to search for hidden tables?
    Thank you for your patience and time......
    Ed M
    [email protected]
    Tuner Chevy406's Avatar
    Nov 2007
    Huntsville, AL
    163
    Will the User Definition feature allow us to create an ignition timing vs MAP table for GM operating systems?
    28,313
    Quote Originally Posted by Witt View Post
    You don't need a bin file for any of it, you can enter the address information into tunerpro without a file open.
    Mar 2008
    St. Louis, MO
    4,863
    You have to either know somebody or pay somebody for information. It's mostly A2L files that you need.
