can i up the "alternator/fuel system voltage minimum"
I see my 2017 camaro has 14.7v in this tab. a 2015 z06 has 15.0v. a 2017 zl1 has 15.5v in this tab.
if I up this number does it up the alternator output voltage? if so what is a safe maximum? it looks like you can configure it so it will only boost the voltage when you need it so it wouldn't be cranked all the time.
I am looking to get more flow out of my in tank pump and am about to buy a jms fuel max but before I do I thought I would ask about this. I have swapped in the zl1 in tank pump.
