Thread: Know if tune is electronic of cable throttle
    How do I know If a tune is for electronic throttle or for cable.
    2001 Jimmy ,L31 with marine intake,CPC conversion,Nv3500 5 speed,SAS,Dana 44's front and rear,4.30 gears..
    13,607
    A P01 computer like that with a 2002 silverado tune file is a cable TB. The following year they switched to a P59 and DBW for silverado's.
    Ok. Thats what I though. Having issues with the TP Sensor. I think it may be junk. Runs better with it unhooked
    That and ALLData is showing it wired up as electronic for some reason
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    You have tabs for Electronic Throttle, but all of the data in the tables are 0.00 so that you know it uses cable.
    ZL1 Wheels/Tires
