I've been using another brand of tuning software for the last 8-9 years and slowly getting into HPT. I created a channel listing and layout with gauges, graph, and chart vs time. All that went great.
I wanted to check on the scan rate, but did not see an option for it. The HPT Help File shows a different table window than what's in the 3.4 software I'm using. I understand the byte limitations with the controller type, but aside from counting each one, is there a place in the scanner that list the number of bytes used and scan rate in frames per second? One last question, do most of you apply filters in the Graphs function or is there a more generic filter that applies to all data displays?
Thanks in advance!
