So we tried to disable the P0101 DTC on a 2007 LMM Duramax but the after effect still is present.
For example under the DTC menu we having disabled the P0101 code. We then run our test on the road and the P0101 code although not being set still puts the truck into limp. It seems the criteria and the result of the P0101 MAF Performance code will still put the truck into reduced power mode even though the code is disabled.
Do I have any other options to disable the after effect or eliminating the truck not going into reduced power mode.
