Originally Posted by
Devildog1325
You need to take what your stit are telling you in your log and apply them to your airflow in the tune for idle airflow I saw Idle trims around 1.85lb/min at some points this will definitely cause hunting issue's.....if I'm reading your log right. I would put all your idle controls back to stock and work in your idle airflow tables before messing with anything else Also why did you increase your gain on your transient fuel but decrease your time constant. And look at your supercharger inlet pressure offset vs rpm, you have changed them but HP has something going on with the software the axis turned to 1000 rpms all the way down. Also why was your displacement decreased?
