4l80e n sloppy trans brake
Anyone have experience using sloppy transbrake? Seems like I'm getting put in limp mode after one pass I get stuck in first gear. Have all codes listed on sloppy wiki disabled set to no error reported. Works fine when it works can build 12# vs 2# on foot brake
https://sites.google.com/site/sloppy...oppytransbrake
I've used it maybe 10 times. Here recently I been getting stuck in first gear afterwards.
Also while logging scanner will quit reading data. Have a log where I did burnout got on 2step n sloppy brake built u psi and log stopped everything went flat. Had to disconnect and reconnect to get logging again
Were you able to find a solution for this? I seem to have the same issue.
