Originally Posted by
Blueprint
You did say you put the stock injectors in and everything was fine?
If it was a sensor, I just don't see how that is possible. The problem should remain the same.
Curious are you factory fuel system aside from the id1000?
**** For sanity sake I just went and checked everything. I'll be damned, the spacers for the fuel rails are making injectors sit too high, some were sitting higher than others, I could move them up and down probably 1/4" ( aftermarket rails id1700). I remember when I checked this prior I heard them snap in, I guess just not far enough.
I remember Shaun @ AED mentioning this a few years ago. I guess when I get a moment I will trim the spacers and grab a few logs.
