Results 21 to 40 of 41
Thread: whipple 132mm tb
    Oct 2007
    Crawfordville, FL
    2,464
    Quote Originally Posted by HPF View Post
    mr.Eric any info for 90mm FRP TB ?
    Sorry I do not have that.
    Eric Brooks
    HP Tuners, LLC
    Mar 2008
    Paris, France
    435
    Damned, Eric, have you delete the 132mm TB data on the post ?
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
    Sep 2010
    872
    Quote Originally Posted by Brice View Post
    wow, look like the post is gone...maybe someone saved the settings...
    May 2016
    1,134
    I wish I had saved it in case I come across a job tuning one.
    Apr 2015
    CO
    99
    Quote Originally Posted by Jn2 View Post
    maybe they did.
  6. #26
    Mar 2016
    48
    I have it , any one wanna it please send pm I'm afraid if I post here Eric ill be mad
  7. #27
    Mar 2008
    Paris, France
    435
    answer from Whipple :
    "Sorry we don't have this data its Ford data a subcontractor at Ford does thecalibrations and we don't have access to it either .
    Thanks "
    what a joke...
  8. #28
    Sep 2010
    872
    Thanks "
    what a joke...
    Sounds like they maybe outsourced it to someone who works at Ford and does tuning on the side so they themselves don't know what the settings are, or Ford has some sort of behind the scenes support channel for these companies(highly unlikely).
  9. #29
    Oct 2007
    Crawfordville, FL
    2,464
    I was asked to remove it. Sorry.
    Eric Brooks
    HP Tuners, LLC
  10. #30
    May 2016
    1,134
    I guess this means there's no chance of you posting their entire tune file then?
  11. #31
    Tuning Addict
    6,903
    Quote Originally Posted by Eric@HPTuners View Post
    Edit - Clarified HPT is still coming out with Whipple support. They were just forced to take down the tables for the time being as they came from HPT and not an individual????? Yeah - OK then....
    ~Greg Huggins~
  12. #32
    Quote Originally Posted by ridenrunwv View Post
    What tables would you want to see?
  13. #33
    Mar 2008
    Paris, France
    435
    Quote Originally Posted by Bugasu View Post
    Speed Density tables :-)
  14. #34
    May 2016
    1,134
    That's actually what I really wanted to see also. Besides just being curious at all the little things.
  15. #35
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    So no upcoming Whipple coverage then? So everything was for nothing then...
    I don't understand the issue - Dustin himself stated he didn't care if someone got through the encryption as clearly stated in this email -
    http://www.hptuners.com/forum/showth...re-Ford-tuning
    I know for pretty much a 100% fact that Ford does their calibrations - yes they're using a FRPP tune setup - is this the problem?
    is the strategy still the same in the whipple tune?
    or did they renamed it?
  16. #36
    Tuning Addict
    6,903
    I'm sure it's changed as it's a Ford FRPP template tune which means even though no one can technically change the tune, they do have access to turning safety's on and off such as if it hits a injector duty cycle limit, cht limit, knock limit and so on - it puts the engine into a partial REP and if the driver keeps trying to push it - it will kill the engine all together until the key is cycled... This also gives the shop basic access to gear ratio and tire sizes, but absolutely no way to adjust the tune to fix all of the problems with it...
    ~Greg Huggins~
  17. #37
    Jul 2015
    927
    Any update on this? I'm looking for a 15-17 F150 Whipple read.
  18. #38
    Apr 2015
    CO
    99
    While I've not seen an F-150 specific tune, if you're looking for 132mm TB data, this post has a tune in it https://www.hptuners.com/forum/showt...ighlight=132mm
  19. #39
    Tuning Addict
    6,903
    Unless it was removed, I posted a whipple f150 tune for a 15'... It was a stock TB though... (OE Whipple is the F150/Latest Whipple is Big TB Mustang)
    Forewarning to everyone - do not copy this OS - it has things in the background to kill the OBD data line, so you can't log it :/ If someone has a newer one - the latest whipple cals are supposed to have this removed...
    ~Greg Huggins~
  20. #40
    21
    GHuggins, I have a 2014 with the 2.9 front inlet and 132 TB and I have been looking at the TB info in my tune vs. the one you posted and they are way different. Any idea why or which is actually correct, or is there a difference between the s197 132 TB and the s550 132 TB? Here is a copy of my tune.
    Thx.
