Results 1 to 9 of 9
Thread: 5.7 + 274 Comp Cam = less than 350 RWHP !!
    Dec 2015
    Riyadh, Saudi Arabia
    71
    Hello
    5.7 hemi with 1 7/8 kooks, 3" magnaflows and 3000 stall
    this car has 274 comp cam in it and it did came from another tuner achieving 340 RWHP i retuned it for couple of hours gaining no more than 350 for some reason.
    what numbers you achieve guys on these application ?
    Apr 2011
    42
    Maybe attach the file so we can see if it can be improved
    Jul 2015
    927
    you need to attach a tune and log. what brand of convertor?
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    depending on if they've got the cams installed properly and phaser kit it should make up to 400whp... 350whp is what a bolt on R/T usually makes...
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Dec 2015
    71
    Attached
    the stall is 3000 FTI
    Apr 2018
    13
    Well honestly man just looking at the tune you sent, it looks like you are tuning this cam with ANN. i would switch to SD, that's how i tune for bigger cams.
    Quote Originally Posted by Duckfan1812 View Post
    he should turn off NN and tune , is this correct ?
    Also looks like PE is pig fat up top ?
    looking at how the trans side is adjusted it seems as if you're doing dyno pulls in first gear, there is no way your whp numbers will be accurate in a 3.6 to 1 gear, it will lower power #s significantly.
    Also I would change the trans tune A LOT.. as well as raise timing.. it should be pulling around 19 to 21* easily.
    Nov 2009
    All Around
    3,149
    guys this thread is 3 years old LOL
