Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 83
Thread: Chrysler SKIM Thread 2.0
    Apr 2014
    722
    Are you certain your issue is SKIM related? Usually SKIM system will allow the vehicle to start and run for a short period of time (something like 3 seconds) , then shut off. However, after a certain number of attempts at starting with SKIM shutting things down, it will not allow startup at all.
    Jun 2016
    has anyone successfully remove skim ? i have a 2006 srt8 with a 2012 6.4 liter . NGC4. if anyone can help please pm .
    thanks
    Aug 2016
    Thunderdome
    390
    so in short, you need the pcm with P5160105 & a 2014+ hemis TB ?
    I have a burrito in my colon, yet refried beans come out...
    How i know it's from the same meal? I didn't ingest corn any other time.
    Jun 2017
    Richards Bay South Africa
    23
    I would LOVE to help with testing SKIM removal.... We are perfect test subjects... installing Hellcats into Rams and doing Jeep swaps etc. Busy with Jeep JK and Hellcat swap with 8 speed auto and desperately need skim remover from GPEC2A
    Aug 2016
    Thunderdome
    390
    good luck....
  6. #26
    Mar 2016
    22
    So I'm guessing we still can't delete skim on dodges? I need to delete a 2005 300c......
  7. #27
    Jun 2010
    304
    Quote Originally Posted by wasyl View Post
    seems so. Syked Ecu Tuning told me he is able to remove it but never tested him, i'm international so i preffered to get factory unlcoked PCM with no SKIM
    best regards.
    How does this work? Example: if i want to do a custom swap with jeep jk engine/trans, if i order a new pcm it will not have SKIM?
  8. #28
    Sep 2018
    30
    Quote Originally Posted by castorjames View Post
    yes...(snipped)
    Yes, correct, however please note that if you forget to unplug/remove the old SKIM module, or if you accidentally plug one in, the PCM will detect it and activate SKIM. Once that happens you are back to square one and dealing with skim again. So make sure you remove the module and make sure you never connect one again. Removing the module and cutting the connector off the wires and securing them will keep you safe from some unknowing mechanic noticing unplugged wires and doing you a 'favour' by plugging it in again.
  9. #29
    Nov 2012
    SF Bay Area -> Wellington, NZ
    66
    Bringing this one back, because i?m Hoping someone has something for me.
    I?ve got a 2016 Challenger R/T engine in a ?70 Cuda, but it won?t fire its own injectors. I flipped the switches for SKIM disable in the tune. Anything else I ought to turn on or off to get it fire off?
    ?I also removed the smog equipment in the tune (egr and air pump disable) and removed the codes for smog equipment.?
  10. #30
    Tuner in Training Blake @ TSS's Avatar
    Aug 2014
    Baton Rouge, LA
    28
    I started this thread a long time ago. HP tuners does not see the value in SKIM removal as we do. I have been able to deactivate vats on Gm engine swaps for years, but no dice on the Chrysler side. I begged and begged for years so I gave up the ghost and went to other venues instead of spending client money with hP tuners.
  11. #31
    Aug 2018
    43
    what ta do?
    I have a customer with an 03 ram big cam can't tune throughout
    so he installed an 05 ECU, I read vehicle
    license vehicle and then wrote entire with both skim disabled
    vehicle cranks over but no injector ground pulse
    after further discussion
    customer shorted pin 38 to ground to enable starter relay
    which leads me to believe that Skim is not letting it crank
    what should we dso now?
  12. #32
    Feb 2019
    16
    What excact model/ year could hptuners remove the skim?
    3 plug pcm doable?
    4plug pcm not?
  13. #33
    Apr 2014
    722
    Quote Originally Posted by ocerrr View Post
    3 plug pcm doable?
    4plug pcm not?
    skim cannot be disabled on ANY dodge applications other than viper.
    There's your answer.
  14. #34
    Sep 2010
    FL
    375
    Has anything changed? Can HP Tuners delete SKIM on anything?
  15. #35
    Banned
    Jan 2018
    Everywhere
    1,772
    Nothing has changed
  16. #36
    Aug 2019
    That sucks there is still no way around it. I have a 2012 ram i'm trying to fire up on a stand. I cant believe that there's no way around it, or even an option to reset skim.
  17. #37
    Banned
    Jan 2018
    Everywhere
    1,772
    There?s plenty of ecm shops that you can send the ecm out to to have it done.
  18. #38
    Aug 2019
    I ended up sending it to http://www.bgperformance.com/ to take it off for $130. It only took a little more than a week to get it back. In VCM scanner before i sent it off it said "SKIM Learned". In VCM Editor SKIM was set to disabled, but SKIM Capable was set to enabled. After getting it back VCM Scanner says "SKIM Unknown", and in VCM Editor both SKIM and SKIM Capable are set to disabled. Now I Just have to figure out why my hemi wont start on the stand.
    *Edit: In VCM Scanner "SKIM Status" still says "SKIM Learned"
  19. #39
    Mar 2012
    Skim
    Quote Originally Posted by Mark@HPTuners View Post
    There isn't much to share at the moment. We need beta testers that can give feedback with what works and what doesn't so I sent him a PM.
    I would be intrested in beta testing of SKIM reset/delete.
  20. #40
    get the key skim box off the column from the car with the matching PCM i got a column, key and PCM from the junk yard for $150 taped the key to the skim box and plugged it in along with the matching PCM and it worked fine
