Hi guys,
I noticed the other night that there is an ETC table that can be scaled with VSS or RPM but when switched to RPM it does not change the column axis??
This is on an E38 and I am not using a VSS and would like to scale this properly.
Also as a possible feature request, in the custom OS is it possible to use something other than VSS to enable DFCO? Unless there is another viable way to input a VSS into an E38 loaded with a truck OS??
Thanks -Steve
