Looking for a little help.
I bought a used ZL1 camaro with some mods, shortly after it started going into limp mode with code P0068 and sometimes also p012b.
I have looked for vacuum leaks, replaced MAF sensor, super charger inlet pressure sensor, throttle body, and accelerator pedal, with no luck.
So I decided maybe its in the tune so I purchased HP tuners Pro suite and am now trying to educate myself with very little luck.
Setting the P068 enable rpm to 8000 stops the limp mode issue , but I would imagine I still have an issue, and I still have the P012b .
Mods
Long tube Headers , cat delete
Roto Fab intake
PRC ported heads
Cam (unkown)
9.55 Lower pulley
Unkown injectors (850 scribed on the side of each injector)
