I want opinions on what wide band is the most compatible with HP Tuners I have an innovate that is from an old set up but it is a pain to setup with hp tuners thank's for your help.
Never had any problems with the past 4 AEM widebands I've purchased.
Thanks!!!
in the past i ran aem sensors without issues. all sensors are pretty much setup the same so once you do one and get it running then no problem.
