Results 1 to 8 of 8
Thread: G8 L76 put in RX8 cranks over but won't start
    Sep 2017
    16
    We did a DOD delete on it. I disabled the VATS and DOD.
    I know the ViPec ECU software well, but first time with HPtuners. Just not having luck getting it to start. Has fuel pressure at the rails. If I hit it with a shot of starting fluid, it will fire. But, it doesn't seem to fire the injectors on it's own.
    Can someone please give me some help? I have included the tune.2009 G8 6.0 6l80e stock tune NO VATS NO DOD.hpt
    13,606
    When the VATS is in the OS tab, it requires a write entire, did you write entire when you flashed it?
    Sep 2017
    16
    Yes I did a complete write
    13,606
    Can you get a log of it starting or attempting to start?
    Sep 2017
    16
    How do i do a log? I can get a log tomorrow.
    13,606
    Use the VCM scanner.
    Then in the channels list after you connect to the vehicle you can add any channel (sensor/parameter) that you think you need to log to be helpful for doing diag.
    If all you did was a cam swap, disable the DoD/AFM and VATS, it should still start no problem. Perhaps something else is unplugged, no power to something, fuel pressure or whatever that is causing the no start.
    Sep 2017
    16
    The only thing that I know isn't connected are the O2 sensors as the exhaust isn't on the car yet. I will get a log tomorrow. Thanks for your help.
    Sep 2017
    16
    Was sick last week and finally worked on it Saturday. I pulled the tune off of the ECM again and it said VATS ENABLED. So, I disabled it and did a full write. Now it starts with no problems.
