Results 1 to 9 of 9
Thread: 13 ZL1 Camaro surging
    Car has a pulley and headers. When trying to make a dyno pull the car surges like the throttle is closing. Anyone have any idea what this could be?
    Here's a scan showing the surge
    Jun 2015
    TN
    189
    Need to post your tune file. The stock estimated MAP setting is 190kpa, and that's when your surge happens. Up that value to something like 250. Its probably opening your bypass valve on the blower. If that setting is still stock
    RPS Twin Carbon Clutch
    Kook's Headers
    Ported Supercharger
    Cold Air Inductions cai
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
    Tuning Addict
    6,883
    Hard to tell without the tune, but this is typically the max boost limit settings of the supercharger parameters... Just raise them up, should go away after that...
    ~Greg Huggins~
    It was still at 190, raised it to 250 like stated. I'll try it in the morning and see if that's it. I sure hope so this has been aggravating.
    Still does it with the kpa raised to 250.
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Can you give me a log with these PIDs? I believe this is TQ management. So in looking at tune I hope your fuel is 95 Octane or better. Lots of timing for a 14psi stock build in a ZL1. I have attached a tune that may fix your issues. DO NOT use the O2 settings as yours have a flaw in them from HPT and are reading the wrong values. The rest including timing I would use. Log with attached PIDs would be nice.
    Nov 2009
    All Around
    3,149
    latest file attached has stock boost settings
    Changing the boost setting fixed it. Thanks y'all
