Results 1 to 10 of 10
Thread: Licensing issue - Read ECM and TCM Separately
    Jun 2017
    22
    As the title implies, I read the ECM and TCM separately, so I have 2 .hpt files - one for each.
    I licensed the ECM file with 2 credits, assuming the TCM would also get licensed.
    I now understand that I should have read the ECM+TCM at the same time, and then licensed that one .hpt file.
    Can the mods merge my TCM data into my already licensed ECM file??
    ...I don't feel I should need to use 2 more credits just to license the TCM.
    Needless to say I won't make this mistake again....Thanks
    hpt_ecm_read.hp.hpt
    hpt_tcm_read.hp.hpt
    28,312
    We can't merge files, simply do a read entire and read both at the same time.
    Aug 2016
    Thunderdome
    389
    Reading entire now shouldnt require additional credits UNLESS it also reads a fcm.
    I have a burrito in my colon, yet refried beans come out...
    How i know it's from the same meal? I didn't ingest corn any other time.
    Dec 2017
    26
    What make and model?
    13,615
    GMC Envoy with E40, the tune is in there.
    Dec 2017
    26
    Its asking you to license both the tcm and the ecm? if the FSCM is showing up to read on the prompt click do not read you shouldnt have to modify the FSCM if you arent using forced induction. Any gm car/truck ive read with seperate ecm and tcm it reads them both the same time and combines them automaticaly.
    Feb 2018
    Morrow, Ohio
    i have the same problem. the first time i read the ecm it didn't read tcm at the same time. i just happened to read the truck to see what tune it had in it and it decided to read the tcm this time now it wants me to license the truck again. Did you figure out what to do with out wasting 2 more credits?
    28,312
    Quote Originally Posted by anspach87 View Post
    read the ecm & tcm at the same time. Most TCM's won't require credits if you read both at the same time.
    Jun 2017
    22
    yes i didn't read both at the same time. I read them separatly (bench harness) so I ended up with 2 HPT files.
    I was simply wondering if the mods could merge the files for me, but I guess not...
    28,312
    Unfortunately not possible, you would need to read them together.
