2016 LT1 vats delete
I did a swap with a 2015 LT1 in a '68 back in February and back then with the current version of hp tuners, it only listed Vats1. 2014 tune files showed vats 1 and 2. After a while.. lots of frustration, the solution at the time was to make it a hybrid pcm with a 2014 flash on the 2015 ecu and it worked like a charm. 2016 and a 8 speed is just like what happened in February (possibly) I downloaded a stock 2016 tune file and it also only shows vats 1. obviously we cannot flash a 2014/5 tune file on it as those are 6l80's.. later there was an update for hptuners and vats 1 is still the only option. I just downloaded the latest from the home page and still shows vats 1 for the original stock 2015 tune file. How does one get vats 2 patch in hp tuners.. is something like this developed and then released? just wondering.
Did you ever figure this out? About to do a LT1 swap for a customer and trying to sort this out before I proceed.
