Thread: Back to Stock
    May 2006
    WPB, FL
    24
    Back to Stock
    Just a idea I had...
    It would be cool if some where in the editor you can load up a "stock tune" which is just a proven, working tune..... then, when you make a huge error you can just click a button that would switch the table back to all values from that other hpt files table....
    What do you think??
    28,777
    yeah the compare feature or using the undo button.
    Every time you make a change, save the file under a new, progressive file name. NEVER make a change without saving it under a new name. If you have a problem and changed more than one thing... How else would you go back? 1.hpt is always the stock file, then go up from there. 2.hpt.... If you need to you can always go back to 1.hpt for the stock tune and start over.
    Mark
    Mark
    28,777
    the history menu's also can help with that showing one change to the next and on what date.
