It's a common MPVI issue with Fords and some Dodges.
I opened a support ticket long ago and was told my interface was faulty, that I needed to buy a new one (offered to transfer my licenses to a new one), however I wasn't convinced.
I borrowed a new interface and it does exactly the same. A friend from another city has a really old interface and he says it does the same.
I have never seen a wrench light, however the interface upsets the CAN network and the cluster stops working, door chime goes crazy (only trucks), A/C turns on by itself (hot air
![Mad](images/smilies/mad.png)
) and can't be turned off, most things won't work (traction control, cruise control, power steering, turn lights etc).
I have isolated the problem to the MPVI since it only happens when it is plugged to OBD2 port, I used SCT and Diablo tuners with the same cars and all worked normally.
I have found that leaving the interface plugged to the OBD2 port for a few minutes before turning on the ignition makes it behave better. If I first start the vehicle then plug the interface the car just goes crazy.
My interface works good and this doesn't happen with any GM to this date.
