hey guys. i have an ls3/t56 (fbody) swapped into a 69 camaro using a bp automotive harness. its running an e38 ecm that shows it being a 2011 silverado.
i had it tuned and it runs great but always reads 158 mph which consequently makes the reverse lockout solenoid stay locked out making it difficult to get into reserve. its set to manual trans in the tune but it still stays locked out. i removed the solenoid and verified its proper operation by applying 12v and gnd to it and it operated as designed. Its also receiving 12 v at one pin of the connector and about .5 at the other, so the ecm is not grounding the pin due to it thinking its going 158mph ( i think anyways)
how do i get it to not see 158mph constantly so my reverse lockout will operate properly. It may also be worth noting that i do indeed have the vss still plugged in
