I installed 3.91 gears into a 2011 Camaro.
Do I update Ratio & Trans to the new gears or just Ratio?
Do I need to change Ratio - Error?
Use the gear tire wizard under the edit tab.
If using an automatic transmission you can have it auto scale the transmission changes for you.
